MF 1759 Oil plug(s) location
   / MF 1759 Oil plug(s) location #1
MarkGrabb
BURNT HILLS, NY
Massey Ferguson 1759
Hello All - A friend of mine that is no longer with us was changing the oil on my Massey Ferguson 1759 over the years. Now, I have the oil and filter to do it myself, but the manual does not show the location of the oil plug. The oil pan appears to be separated into two sides with two plugs, but before I guess... I wanted to ask if anyone can confirm the location (or perhaps locations) of the oil plug(s) for a MF1759.
   / MF 1759 Oil plug(s) location #2
If that split pan is underneath the engine, I'm certain you have it right. My Kubota, and many other machines have a similar oil pan setup. Remove both to drain.
   / MF 1759 Oil plug(s) location #3
On my Boomer 40 the front driveshaft bisects the oil pan. There is a drain plug on each side of the driveshaft. The drain plugs have copper crush washers on mine so I always make sure to have two new washers on hand before changing oil.
1996 INTERNATIONAL 4700 4X2 DUMP TRUCK (A51406)
1996 INTERNATIONAL...
2019 JOHN DEERE 310SL HL BACKHOE (A51406)
2019 JOHN DEERE...
2017 Bomag BMP 8500 Walk-Behind Articulated Tandem Compactor (A51691)
2017 Bomag BMP...
2006 Ford E-250 Cargo Van (A51692)
2006 Ford E-250...
2006 John Deere 317 Skid Steer (A52384)
2006 John Deere...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
