Traction MF 1754 4 wheel drive, Front axle vent leaks oil
   / MF 1754 4 wheel drive, Front axle vent leaks oil #1
ROGERCORBETT
cincinnati, ohio
massey ferguson 1754
I have a 2016 Massey Ferguson Model 1754 with four wheel drive that has an aggravating issue. The front axle unit has a vent on top of the casing that leaks the hydraulic oil out if it is parked with the vent to the downhill side. The owners manual states that the oil level should be 1/2 of the way up on the axle. This axle is very difficult to see the level properly.
I have a New Holland model 1920 that the front axle is not vented, hence no leaks.
Has anyone esle had this issue ?
   / MF 1754 4 wheel drive, Front axle vent leaks oil #2
My guess is that there is too much oil in the axle housing. The top of the vent is way higher than the middle of the axle housing so the tractor would have to be on an extreme side slope for the oil to leak out. Try parking the tractor on a FLAT surface and using a flashlight to look into the fill hole. If you cant see the axle shaft then the oil is too high.
WOODS RT48.30 LOT NUMBER 235 (A53084)
WOODS RT48.30 LOT...
2021 Ford F250 4X4 Service Truck (A52377)
2021 Ford F250 4X4...
2025 Star EV Capella 2+2 Electric Golf Cart (A51694)
2025 Star EV...
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR29J160609 (A51572)
2009 International...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
INOP/NON-RUNNING 2008 International 7300 Truck, VIN # 1HTWAAAN78J690166 (A51572)
INOP/NON-RUNNING...
