MF 175 Hydraulic fluid dipstick location
   / MF 175 Hydraulic fluid dipstick location #1
ONELUGNUT
Visalia,CA
MF 175
I can not find dipstick am I that blind?:(
   / MF 175 Hydraulic fluid dipstick location #2
No you are not blind. The photo does show the dipstick though.
Beside the difflock pedal below the 3ph response control slider is a recess for the diff dip stick . The photo shows it is covered in dirt and easily overlooked, also the handle loop is sitting flush which makes it even harder to spot.
I hope the description is good enough, it is easier to show than describe. It would be very easy if I knew how to put an arrow on the photo.
I found it. Thanks a bunch :) Hard to tell I have spent 3+ hours with the pressure washer on this thing.
   / MF 175 Hydraulic fluid dipstick location #4
Easy when you know where to look and frustrating when you don't isn't it.
Just curious, how much oil was in there?
Multipower or 6speed?
Safety Basket (A50121)
14' Bi-Parting Gate (A50121)
14' Bi-Parting...
2014 GALYEAN 180 BBL STEEL VACUUM TANK TRAILER (A52472)
2014 GALYEAN 180...
2018 Jaguar XE Sedan (A50324)
2018 Jaguar XE...
Welder (A50121)
Welder (A50121)
