MF 175 3 pt stopped working
   / MF 175 3 pt stopped working #1
SDAXE
MF 175
Have a MF 175, no hydrostatic tranny. I have remote hooked up but don't use. I was bush hogging the other day an went down a small burm. The bush hog blades contacted the ground and I heard a loud pop. 3 pt hydraulics stopped working and i can't get them to lift. No leaks. Control levers seem to be easier to move. i checked the valve on the remote cover and it doesn't appear to have moved. Any help is appreciated.
   / MF 175 3 pt stopped working #2
I am not familiar with the 175, but it sounds like you damaged the hydraulic pump some how ( that's the polite way to say broken shaft or gear). Do you have anything you can connect to your remote to see if you have hydraulic pressure??
no, i don't have anything for the remote. i suppose i could hook up a pressure tester to the remote and to the main pump before i dig into it. The pto is still working.
   / MF 175 3 pt stopped working #4
the pto and the hydraulic pressure circuit are not related so even with the the 3pt lift out you should still have the PTO.
   / MF 175 3 pt stopped working #5
Loosen a fitting on the pressure line and see if there is any fluid coming out under pressure. Put a rag over the fitting and stand back from it. Just crank the engine about 20 sec.
EZ-GO D499 Electric Golf Cart (A51694)
EZ-GO D499...
Bestway Ag 3pt 55 Gal Spray Rig (A50120)
Bestway Ag 3pt 55...
1994 Toyota 6000lbs 2 Stage Forklift (A52748)
1994 Toyota...
2019 KENWORTH T680 SLEEPER (A52577)
2019 KENWORTH T680...
Rears 500 Gallon Orchard Sprayer (A50120)
Rears 500 Gallon...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
