MF 165D blow by? new crank & mains...
   / MF 165D blow by? new crank & mains... #1
Farmer Ben
Can anyone tell me where the blow by pipe is on the MF 165D engine? Also, why would the crankshaft and main bearings need to be replaced besides normal wear & tear? How can I tell if the pistons & rings do not need replacement?:confused:
Thanks, Ben
   / MF 165D blow by? new crank & mains... #2
Thanks, Ben
Vent pipe is on left side of block, near front IIRC.
Possible causes for premature bearing wear could include; Fuel leaking into crank case (via leaky injector pump, leaking primary fuel lift pump, ect) ......Coolant leaking into crank case via a number of sources......lack of proper service of oil/filters.....among hundreds of other possibilities. Fuel leaks are not UNcommon, and may have even occurred years ago with bearing wear escalating from that point forward.
Worn/broken rings USUALLY are accompanied by excessive blowby, lack of compression, poor starting (due primarily to lack of compression..) excessive oil consumption, and obvious lack of power. Worn pistons CAN cause a "noisy" engine...not to mention possible catastrophic engine failure if left as is.
On an engine that typically last's 40+ years under normal circumstances, I'd always replace pistons and sleeves if I was going as far as rings....If you get ANOTHER 40 years out of the second set, it aughtta outlast most of us!
Thanks Farmswithjunk! Very good to know. Went to go see the tractor and it was sold! Oh well...
2016 Ford F-350 Ambulance (A51692)
2016 Ford F-350...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2016 John Deere 5055E 55HP Utility Tractor (A52377)
2016 John Deere...
2020 Mclanahan 150 TPH USP Wash Plant (A52377)
2020 Mclanahan 150...
2008 STEPHENS 220BBL CRUDE OIL TRAILER (A52472)
2008 STEPHENS...
AMADAS SPC-6 LOT NUMBER 257 (A53084)
AMADAS SPC-6 LOT...
