MF 1655 pto
   / MF 1655 pto #1
rednose39
Massey Ferguson 1655
I have about a 1978 MF 1655. The front/mid pto shaft is loose in the housing and not turning smoothly. I would think it needs new bearings and possibly new shaft. I would like to remove the shaft and bearings but not having any luck, with snap rings off I thought the shaft would come out but it's not. Does someone have any ideas.
   / MF 1655 pto #2
I took mine out last year and if I remeber correctly you have to take both big nuts off either end as the brgs sitting inside the nuts.The shaft will come out easy after you do that.I kinda think the shaft has a snap ring on the inside if I remeber correctly.Larry
   / MF 1655 pto
Ok thanks, I wasn't sure if those big nuts actually turned or not. I'll try those next. thanks again
2010 Ford F-150 4x4 Pickup Truck (A51692)
2010 Ford F-150...
2013 New Holland T4.75 Tractor (A52384)
2013 New Holland...
1999 LBT INC FUEL TRANSPORT TRAILER (A52472)
1999 LBT INC FUEL...
2019 CATERPILLAR 289D3 SKID STEER (A51246)
2019 CATERPILLAR...
2,500lb Traveller ATV Winch (A51573)
2,500lb Traveller...
