MF 165 steering control valve
   / MF 165 steering control valve #1
DLinMI
Decatur, MI
MF-165
Steering control valve was leaking bad so I replaced the o rings and seal, discovered that the reason it was leaking was someone had it apart before and left out one washer and the snap ring that holds the spring in place, the spring was pushing the oil seal out of the assembly. Well now it's all back together but not working, I failed to mark the steering arm before removing it from the pedestal shaft and feel that I have it "out of time" so to speak. I've adjusted according to the manual, but I've got some slop in the mounting pin cylinder rod area and don't know how to adjust so the valve is activated at the right place or time when turning. Where should it be when the steering is straight ahead, and left or right? Thanks
1992 Kenworth T800 Semi (A50514)
1992 Kenworth T800...
New Power Line 500 Metal 3pt. Spin Spreader (A50774)
New Power Line 500...
Great Plaines 2400 Tt (A50514)
Great Plaines 2400...
Heritage / Woods RD 72 3 pt Finish Mower (A50515)
Heritage / Woods...
2004 DYNAPAC CA152PD PADFOOT ROLLER (A51242)
2004 DYNAPAC...
2018 BOBCAT T450 SKID STEER (A51242)
2018 BOBCAT T450...
