MF 165 Multi-power, aux pump for externals too?
   / MF 165 Multi-power, aux pump for externals too? #1
dcharette
Czech Republic
Massey Ferguson 165
Hi All,
So, I've been messing around with a new valve to give some additional hydraulic control capability to my 165. There's another previous thread about it.
Anyway, it's come to my attention, through this project, that it's not quite the most ideal way to run external services with the main hydraulic pump used for the 3pt.
I have a 1965, 165 model with a multi-power transmission. And what's not entirely clear to me is if this multi-power clutch is run by a seperate aux pump?
And, if that's the case, is this the same aux pump that is installed for adding external hydraulic services, with the ports typically installed on the plate where the PTO engage lever is at?
And finally, if that is true, can this aux pump be plumbed to feed both the multi-power clutch and the external port at the same?
I didn't want to crack the tractor open just to see, was hoping someone already has crossed this bridge.
Thanks for the help! :)
Dan
   / MF 165 Multi-power, aux pump for externals too? #2
Yes, it's the same pump, a few have just a small pump just for MP but that's uncommon. Picture of the PTO cover would be nice
2020 Lincoln Naultilus (A50324)
2020 Lincoln...
1270 (A50490)
1270 (A50490)
International 1420 Combine (A50514)
International 1420...
2015 CATERPILLAR 745C 6X6 OFF ROAD DUMP TRUCK (A51242)
2015 CATERPILLAR...
UNUSED MOWER KING SSAB72 ANGLE BROOM (A51244)
UNUSED MOWER KING...
2018 ISUZU FTR 24FT BOX TRUCK (A51222)
2018 ISUZU FTR...
