mf 165 inj pump leaks
   / mf 165 inj pump leaks #1
cowboy4s
okmulgee,ok
mf 165
165 diesel inj pump leaks around backend of pump, where it is put together from what I can tell. is this an easy fix or not?
   / mf 165 inj pump leaks #2
If leak is at hydraulic head end cap it may be possible to fix on engine. If head to housing seal leaks it must be torn down after removal from engine. Just resealed one for a 135 and mailed back to Missouri. Have found is usually better in long run to replace all gaskets and seals, patch jobs start leaking somewhere else soon after. Pump is not hard to remove/replace, is simple to time also. Be glad to explain if you like call 574 893 4172 after 7 PM Eastern time, can talk faster than type.
2003 MERCEDES-BENZ SLK-Class (A50324)
2003 MERCEDES-BENZ...
2019 Bobcat E32i Mini Excavator (A50322)
2019 Bobcat E32i...
UNUSED TOPCAT QUICK ATTACH HYD 4N1 COMBO BUCKET (A51244)
UNUSED TOPCAT...
LOT LOCATIONS (A52141)
New 4x6 Chicken Coop (A50774)
New 4x6 Chicken...
