3-Point Hitch MF 165 hydraulic arms all up or all down nothing in middle
   / MF 165 hydraulic arms all up or all down nothing in middle #1
desross
Helensville
mf 165
Is there an adjustment as my arms have no middle ground its all up or all down. cant get anything in the middle at all
any thoughts on where to start looking
cheers
des
   / MF 165 hydraulic arms all up or all down nothing in middle #2
To control the height on the arms you use the inside lever (position control) .
The outside lever is draft control and should be in the fully up/back position at all times. It is only used for ploughing.
Which one are you using?
What year is your tractor, there are 2 types of control layout?
   / MF 165 hydraulic arms all up or all down nothing in middle #3
Also did this start all of a sudden or has it been a chronic slow growing issue for a long time ? My first guess is air in the system somewhere. Plenty of hydraulic fluid in it ? Might suck air if low on fluid. I gather from it being a MF 165 it probably has some age and possibly high hours on it. If so, that could be many grungy things I don't want to think about -- seals, the lift control valve, etc.
Good luck with it and let us know the outcome.
Mower King Q.A Pallet Forks (A50121)
Mower King Q.A...
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
2022 Weber CR5-II HD Reversible Plate Compactor (A50322)
2022 Weber CR5-II...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
2015 BMW 328i Sedan (A50324)
2015 BMW 328i...
