G'day rickard.
The pto clutch can be adjusted through the hole in the bottom of the clutch housing and the transmission clutch is adjusted by loosening the Clamp bolt on the clutch shaft and turning the yoke a bit on the shaft ,when adjusted properly the pedal should have two to three inches of clearance.
Hutch.
