MF-1533 Air in Hydraulic Lines
   / MF-1533 Air in Hydraulic Lines #1
kenhardin
Massey Ferguson 1533
I have a 2008 MF-1533 with Synchroshuttle transmission. If the tractor sits for a day or so the 3-point hitch and FEL do not work at all…power steering works fine. To get up and going I have to open the bleed screw on the rearward hydraulic pump and turn the steering wheel until the air gets chased out. Then the hydraulics work fine, until the tractor sits again. Any ideas as to where I’m drawing in air??
   / MF-1533 Air in Hydraulic Lines #2
Leaks in cracked hoses is first guess. I thought the steering and 3pt pumps were two different pumps (??) I assume you already checked fluid levels. Very puzzling why turning the steering wheel makes even a temporary change in the rear hydraulics...
JWR- thank you for your advice!
Ps- I’m not certain that turning the steering wheel helps out at all. It’s just something I’ve done while waiting for the air to clear out. Thanks again!
  • Good Post
Reactions: JWR
   / MF-1533 Air in Hydraulic Lines #4
I'm with JWR on this one. Check the suction hoses on the pump/pumps. One might be cracked, letting air in and causing the pump to lose prime.
   / MF-1533 Air in Hydraulic Lines #5
yeah I was just typing look towards suction side when ptsg post showed up
Thanks all, I appreciate you taking time to share your advice!
2014 Dodge Ram 3500 Laramie Crew Cab Pickup Truck (A46684)
2014 Dodge Ram...
2016 KENWORTH T680 TANDEM AXLE SLEEPER (A50046)
2016 KENWORTH T680...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A46683)
2025 Kivel 48in...
2013 Ford Edge SUV (A46684)
2013 Ford Edge SUV...
2004 Sterling L7500 T/A 12/14 CuYd Dump Truck (A46683)
2004 Sterling...
2021 John Deere 17G Mini Excavator (A46683)
2021 John Deere...
