MF 1523
   / MF 1523 #1
gunbunny
Looking for opinions on the MF 1523. I had considered the JD 2305 and Kubota 7510 but looks like the MF is a much better tractor. I am planning on getting a FEL, finish mower, box blade and auger. I only have 5 acres with 2 acres of mowing to include sodded area along with some woods that I want to clear some underbrush and a road to maintain that goes to my pond. Thanks in advance!! Looking to get this soon.
   / MF 1523 #2
I wanted to look at the 1523 about a year ago, but couldn't find anyone in central ohio that stocked them. I got the impression MF doesn't move a lot of this model. If you look at the lift capacities (3pt and FEL) you'll see they really don't compare very favorably w/ like priced competitors (JD 2320, NH TC23, etc).
The dealer I spoke with indicated they could sell me a 1528 for less than a 1523 since they had the 1528 in stock. If the $ is the same, you might try taking a look at the slightly larger 1528 if your're looking for a gear tractor or go for the 1531 if you're looking for a HST. If you're going to get a HST transmission, I recall the 1531 is only like 400-500 more than the 1528 HST and the HST is standard on the 1531. The 1531 I believe uses the same engine as the even larger 1533.
I ultimately went w/ a JD 2520, but still think the 1528 and larger MF's are a lot of tractor for the $.
Good luck.
   / MF 1523 #3
hi gunbunny
You may want to try out the 1528, I did, and haven't regreated it for anything, I got the package dear here in oklahoma.
06 1528, FEL, box blade, mf 1005 brush hog, and 16' trailer, $17,000.00-
out the door.
I made the best choice, for myself and haven't looked back.
good luck
David
   / MF 1523
Thanks for the replies!
Ford 4600 (A50120)
Ford 4600 (A50120)
Bobcat 3400 4x4 Utility Cart (A51691)
Bobcat 3400 4x4...
16FT Flatbed Trailer (A51573)
16FT Flatbed...
2014 Kubota M8560 (A50120)
2014 Kubota M8560...
2014 Ford Flex SUV (A50324)
2014 Ford Flex SUV...
2018 FORD F-150 (A52472)
2018 FORD F-150...
