MF 1523 Questions.
   / MF 1523 Questions. #1
WilliamBos
Super Member
Innisfil, Ontario, Canada
MF 1635 12x12 Powershuttle
Hi All,
Dad & I stopped by our local MF dealer today, and were looking at compacts. Gonna get one next summer.
We saw a nice little 1523. I was looking at the specs online, and it lists the PTO as being "Trans driven/independent 540 RPM. What does this mean? If the tractor is not moving, the PTO will not be working?
Thanks in advance,
Will
   / MF 1523 Questions. #2
WilliamBos said:
Hi All,
Thanks in advance,
Will
The rear PTO works while the 1523 is standing still.
EanJay
   / MF 1523 Questions. #3
The gear version (trans driven) will keep pushing you. The hydro version has an independent PTO.
   / MF 1523 Questions. #4
1523 hydro has an indepentent hydraulic PTO clutch driven of the hydro (it will not push the tractor), 1523 standrard has an over running sprague (oneway) clutch, will make a harmless racheting noise as the PTO winds down if you disengaged the PTO with an implement hooked to it.
   / MF 1523 Questions. #5
I guess that they are trying to save paper when they won't put in an extra line to separate the different versions. They don't need to with the liters/ gallons, cc/cubic inches but they do need to on transmission types and other things. All the manufactures do it and it does confuse many I'm sure.
I wasn't saying that the independent PTO in the hydro would push the tractor. I was referring to the engine drive version. Engine driven PTOs without an over running clutch will drive a tractor. I wasn't aware that the standard transmission version of the 1523 had an internal over running clutch. Do you have a picture of the sprague assembly area? If you do, can you post it?
So what does this mean? ( Not a ground drive PTO, correct?) And how does it work? Is it as reliable as the live PTO? What are the down falls? We will be doing a lot of PTO work, and want to know know if there are any down falls? We probably won't need anything bigger than a 1523, but would the extra money be worth the upgrade ( to a 1528 )?? We also plan on keeping it a long time, so we want to make the right choice.
Thanks,
Will
   / MF 1523 Questions. #7
Will,
Go to TractorSmart home page. Click enter then Click on the Info button at the top of the page. Then click on Tractor Power Take Off. It gives a pretty good description of the different types of PTOs.
A tractor with a trans driven PTO with or without a overrunning clutch isn't the best for PTO work. It is good to keep the cost of the tractor down.
   / MF 1523 Questions. #8
Both versions are reliable, just different ways of accomplishing the same thing. Attached is a drawing of the sprague clutch assy
   / MF 1523 Questions. #9
attached is sprague clutch assembly
  • sprague clutch.PSD
McDon 75s 40' Flex Draper Head (A52349)
McDon 75s 40' Flex...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
2003 John Deere Power Unit (A50121)
2003 John Deere...
John Deere 6175M (A50120)
John Deere 6175M...
Year-A-Round 550 Gravity Wagon (A50774)
Year-A-Round 550...
Sky Trak 10054 Legacy 10K Telehandler (A51573)
Sky Trak 10054...
