MF 150 diesel, engine and or steering question.
   / MF 150 diesel, engine and or steering question. #1
MasseyLady
Bronze Member
Ohio
MF150 Perkins Diesel & MF135 Continental Gas
We have a 1967 MF150 diesel that we notice when it is in neutral and running if you turn the front wheels to the
left the sound of the engine reduces and if you turn the wheels to the right the sound of the engine increases.
I do believe hubby has noticed this when it's in gear and being driven, I will have to double check with him to
be sure. It does have power steering. Does anyone know what the problem could be?
:tractor:--MasseyLady
   / MF 150 diesel, engine and or steering question. #2
Most of your PS mechanisms and adjustments are behind the front grill. Sounds like the travel is maxing out travel in 1 direction and not the other. Reworking and adjustments in that area are relatively simple if you know what you are doing. Ken Sweet
Thank-you very much Ken. We had figured it had something to do with the power steering and noticed the pump behind the grill. We will have to get the service manual out and take it from there. Thanks again.
   / MF 150 diesel, engine and or steering question. #4
Don't be surprised to find some linkage hole elongated. This will need to be corrected first thing. Ken Sweet
Thanks again Ken, will pass the info onto hubby. We really appreciate your input.
Hubby also indicated today that he thinks it takes a lot of effort to even turn the tractor. Could it be it's low on power steering fluid, or could the pump be bad? If low on fluid do you use the same fluid you would use in the transmission, or is their a preferred other product?
   / MF 150 diesel, engine and or steering question. #7
G,Day massey Lady.The first thing to check is the Power steering filter it is inside the pump reservoir right hand side round with a square hex pfiller plug ,remove the centre nut and the reservoir the filter is inside there ,it is held in place with a spring and a pin You will find it easier to remove the complete rod with the thread use Vice grips it is not that tight remove the filter and replace ,or if it is not to bad give it a gentle wash out in petrol/gasoline remember it is a paper element ,if it is not to hard to get one i would replace it if not !!
The Next thing to do is check the power steering fluid level the power steering pump and reservoir is on the right hand side of the tractor ,the reservoir is the round cylinder with the Square drive plug ,with the engine stopped remove the plug SLOWLY there could be a little bit of trapped pressure in there ,this is done more safely with the tractor cold ,remove the plug and top up to the BOTTOM of the threads ONLY use dexron 2 ,auto trans fluid ,atf THE SAME POWER STEERING FLUID USED IN MOST GOOD CARS THE RED STUFF.
Start the tractor with the filler plug removed and if you can, turn the steering full lock left and right to expell all the air from the system keeping an eye on the level as you go remember do not overfill , If the power steering works the same both left and right all should be good ,if not and you find as mentioned that the tractor favours left or right.
First remove the transmission oil cooler the little one in front of the radiator ,it is secured with a long 5/16 " bolt with a wing nut just loosen the wing nut and pull the top of the cooler towards you and lift it up out of there leaving the hoses attached then get your favourite husband or your favourite wife to rock the steering wheel say 1/2 turn either way with the engine running and at the same time look on top of the power steering ram ,you will see a valve with a hex adjustable link secure by two lock nuts.
lets say the steering is easier to turn right than left undo one of the lock nuts that stop the long hex adjuster from turning : note one of the adjusters has a left hand thread You want to MAKE THE ADJUSTER LONGER do this by turning the long hex adjuster 1/4 turn at a time and try until the steering is BALANCED ,retighten the lock nut and recheck the fluid level remembering to fill only to the bottom of the threads ,this will allow for expansion when things get hot ,you will also notice that the power steering control valve leaks oil A seal repair kit is available and it is neither expensive nor to difficult to replace this may not stop the leak but it will certainly slow it down Ha,Ha.
If you check the fluid level and find the level low it can leak from either the Powers Steering ram seals, the transmitter valve or the power steering pump drive shaft ,if it is loosing fluid and you cannot see any obvious external leaks then it will be leaking from the pump shaft ,remove the pump and replace the seal using a GENUINE PART ONLY the seal is a double acting seal that is it seals the power steering oil in and also seals the engine oil out ,do not confuse the seal with a more common DOUBLE LIP SEAL it is NOT again buy GENUINE PARTS or take the sample seal to a seal supply company and make sure they know that the seal is special .
After all that if the steering does not work properly let me know and i will talk you through the factory setting procedure and checks, I hope this is not to confusing .
Happy Days .
Hutch.
Thanks so much Hutch, means a lot to us for you to take the time to explain in detail what we need to do. We have been very busy here, so it will be some time later to check out what you have suggested for us to do. Hubby did get as far as filling the power steer fluid to the correct level, it was low, so we do need to check those seals. We did notice that is does favor one side more than another upon turning the front wheels, so we need to do adjustment there. Again thanks Hutch and G'day to you too! :)
EZGO (A50324)
EZGO (A50324)
Miles read : 112,969 (A50323)
Miles read ...
2012 International 4300 Reefer Truck (A52748)
2012 International...
2017 Ford F-150 Pickup Truck (A50323)
2017 Ford F-150...
New Power Line 400 Plastic 3pt. Spin Spreader (A50774)
New Power Line 400...
2006 Komatsu PC400LC Hydraulic Excavator (A50322)
2006 Komatsu...
