MF 1433 Hydraulics in Cold Weather
   / MF 1433 Hydraulics in Cold Weather #1
wayne48
Bronze Member
Vermont
MF 1433v
Howdy,
I've had my MF 1433 for 4 years and love it! Up here in Vermont, it has always performed well for me in the heat and cold. One thing I do notice tho is that the FEL joystick is stiff to operate in cold weather until the tractor warms up. I've been told that this is due to moisture freezing in the actuator cyclinders of the joystick. Is this true? If so, is there a fix?
Thanks for any suggestions.
   / MF 1433 Hydraulics in Cold Weather #2
I don't see how, because the valve is completely covered to where rain can't get to it. I would say that it is because the fluid is still cold. When the fluid gets warmed up, then it thins and the valve works better.
   / MF 1433 Hydraulics in Cold Weather #3
Colh yydraulic oil is thicker and more slugish. Tolerances within the valve itself could also get a little tighter in extreme cold.
Thanks Jerry- what you say makes sense to me. Not having a lot of experience under my belt, I thought I'd throw the isssue out to you more experienced guys.
Thanks - see my reply to Jerry.
1267 (A50490)
1267 (A50490)
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52141)
2018 INTERNATIONAL...
Komatsu Midi Excavator (A51691)
Komatsu Midi...
Land Honor Skid Steer Pallet Forks (A50515)
Land Honor Skid...
LandPride PFL1242 Pallet Forks (A50120)
LandPride PFL1242...
Unused 2025 CFG XZ20R Mini Excavator (A50322)
Unused 2025 CFG...
