MF 1355 won't run
   / MF 1355 won't run #1
rosco2
Tractor runs for 20 to 30 minutes and then dies, surges, dies. Let it sit for 1 hour and it will run for 30 minutes or so and start dying. 8 second cycle of rpm going down to almost idle, surge, idle, surge. Cleaned tank and fuel lines. No help. Changed fuel. Replaced fuel lines, fuel filter, fuel cutoff valve. The problem continues. Local dealer says he does not know what further to do. Do I turn this tractor into yard art? Very expensive yard art. Help!
   / MF 1355 won't run #2
Im confused did you mean to say 1533 by chance.
edit- Just looked back at your old post and see that you posted about a 1533
So if it is a 1533 have you checked to see if the electric fuel pump is working.
May be getting hot and shutting down. It cools off in an hour and fires up and runs for a bit.
(INOP) KUBOTA B7510 TRACTOR (A51247)
(INOP) KUBOTA...
2009 MAC MFG 53' WALKING FLOOR REFUSE TRAILER (A53426)
2009 MAC MFG 53'...
2019 Nissan Frontier Pickup Truck (A51692)
2019 Nissan...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2007 CHEVROLET SILVERADO K150 CREW CAB TRUCK (A51247)
2007 CHEVROLET...
2025 AGT 750 (A50123)
