MF 135 wheel misaligned
   / MF 135 wheel misaligned #1
Tedemoomaw
Omak WA
MF135
I have a MF 135 with a straight axle, the right front spindle broke and after replacing the spindle the right front is 2-3" toed out. Nothing appears bent. I have ran out of drag link adjustment. Any help would be appreciated.
   / MF 135 wheel misaligned #2
Are you sure you got a spindle for the correct side, it is possible the keyway could be in a different place on the other side of the tractor. The other thing you can do is pull the arm off at the steering box and possibly reposition it to make things work.
I put two different spindles on the previous part# 897236m94 had the same problem as the current spindle on it now part# 508546m92. Can a new key slot be cut in the spindle? On the arm adjustment, is that at the end of drag link?
   / MF 135 wheel misaligned #4
Picture?
2018 KENWORTH T800 (A53843)
2018 KENWORTH T800...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
1982 LeeBoy Motor Grader (A53473)
1982 LeeBoy Motor...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
