MF 135 shifter issue
   / MF 135 shifter issue #1
ntalbot
Freeland
MF135
Hi,
I have a '67 MF 135 stuck in first gear. In the past I've used the screwdriver method through the fill plug dozens of times, with great results. Now, however, the problem has worsened and there are two developing issues: a) the gear now takes LOTS of force to pry from first or reverse back into neutral. b) even when i eventually get it back to neutral the shifter is still stuck. Any suggestions would be great. I'm hoping I don't have to take the transmission apart!
   / MF 135 shifter issue #2
that might be your only hope.....it sounds as if your overshifter gear selector is hanging up on detentes or is worn so bad it tips and then hangs up. take the lid off and see whats up....
ive done a ton of tyranny......send some photos to Spokane 1.
Unused Delta Crash...
JOHN DEERE 7R210 LOT NUMBER 49 (A53084)
JOHN DEERE 7R210...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
INOP/NON-RUNNING 2006 Mack CV713 Granite Truck, VIN # 1M2AG11C56M039887 (A51572)
INOP/NON-RUNNING...
2009 CHEVROLET SILVERADO (A52472)
2009 CHEVROLET...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
