MF 135 pumping oil out dipstick
/ MF 135 pumping oil out dipstick #1
theviking
Monticello, Fl
MF 135
My perkins powered MF 135, started pumping oil out the dipstick. I noticed that my usual oil presure of 40, was stuck at 80 psi. At the advice of my neighborhood tractor guru, I pulled the head off. The old gasket appeared ok, no signs of excessive wear or tracking on head or block, no obvious cracks. Other than spilling oil everywhere, the engine was running good. I bought the tractor last year and have only put about 30 hrs on it, trouble free till now. Any suggestions what to go after next? I do my own work because I can- old hot rodder- and generally do a better job, just not familiar with the diesels.
/ MF 135 pumping oil out dipstick #2
You have put 30 hours on it or it has 30 hours on it? I'm assuming that since it is a 135 it has a lot more hours than 30. So it is making oil so to speak? In other words the oil volume is increasing? I'm guessing it is a diesel, you didn't say. If it is it is either leaking diesel into the crankcase or water.
Does the oil smell like diesel? Most times when it does the seal between the injection pump and the drive for that pump is leaking and pushing diesel into the crankcase.
/ MF 135 pumping oil out dipstick #3
Is the level of the crankcase oil increasing? If it is, you have a leak into the crankcase. Any sign of water? Does it smell from diesel?
If the level isn't increasing, then you have excessive blowby. Look for worn rings, cracked piston, or burned piston crown. Since you had the head off, I presume you would have noticed a burned piston crown.
Check the oil pump relief valve. It may be stuck closed. That can make your oil pressure rise.
/ MF 135 pumping oil out dipstick #4
G'day first and easiest stop if the oil is thin and smells of diesel is the lift pump a tiny hole in the diaphragm will put fuel into the oil.
Jon
Kubota ZG222 (A60462)
BRIGGS & STRATTON PORTABLE AIR COMPRESSOR (A64276)
BRIGGS & STRATTON...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
2019 International LT625 Sleeper 48" (A62613)
2019 International...
2018 WANCO WTSV PORTABLE ARROW BOARD (A60429)
2018 WANCO WTSV...
2002 FORD UTILIMASTER 4X2 S/A STEP VAN (A59912)
2002 FORD...
