MF 135 Perkins Gas 3 Cylinder - Power Down After Warm - Won't Restart
   / MF 135 Perkins Gas 3 Cylinder - Power Down After Warm - Won't Restart #1
slhilbert
Bronze Member
Noblesville IN
Massey Ferguson 135
I am having issues with my MF 135 Perkins Gas 3 Cylinder again. The tractor is starting right up and running great as long as it is idling. When I power up and start driving it around, pretty quickly it bogs down and dies, almost like it is starving for fuel. Once this happens you can't start the tractor again until it sits for a while, and then it will start right up and does the same thing. I have had this problem in the past, but I would have to run the tractor for like 30 minutes and playing with the choke seemed to resolve it. If I could get the choke in the exact right spot the tractor would run no problem continuously. I can't seem to make that magic happen anymore.
Some Things I have Observed
  • Also the key start has been hit and miss, sometimes it starts with the key, and sometimes nothing. The safety switch is working. I did replace the Voltage Regulator and that might have resolved this issue, but I haven't used the tractor enough to be sure.
  • I did take the carb apart and clean it all out, not saying I did it right ;)
  • A few years ago I had to replace the distributor shaft and after that work it ran fine. I have played with the timing a bit by rotating the distributor to see if something was going on there.
  • The power down feels like it is thirsty for fuel, but I am like 96.3% sure the carb is getting the fuel it needs.
  • Part of me wonders if it is electrical, but not sure why I really think that. I have replaced the plugs and the wires, but with the ignition issue it makes wonder.
  • I have found when stuck in a field I can use a remote starter and continue to turn the starter, the tractor actually runs pretty good and I can at least get it back to the garage.
I worry that something internal in the engine is heating up and expanding and that is why I am having issues.
I am a bit at a loss. I love this old tractor, but not sure how to fix it at this point.
Thanks for the help!
Stuart
   / MF 135 Perkins Gas 3 Cylinder - Power Down After Warm - Won't Restart #2
I don’t own the same model but I have had similar and it traced to fuel almost every time.
Tank Vent obstructed and an easy test is try with the cap removed.
Carb Float stuck limiting volume of fuel flow… fine for idle but not under load.
I’ve also had a bad condenser that produced a weak spark to no spark when hot.
Also, once had a coil that was weak… and it produced a weak spark.
I have a 1940’s Snap On coil tester I picked up years ago and it makes for easy testing.
Spark, Fuel and Compression required.
   / MF 135 Perkins Gas 3 Cylinder - Power Down After Warm - Won't Restart #3
I suspect your float level is set incorrectly or the needle is sticking.
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
2013 International WorkStar 7400 4x4 Altec DMA71 Insulated Digger Derrick Truck (A51692)
2013 International...
2024 JOHN DEERE FC20M LOT NUMBER 74 (A53084)
2024 JOHN DEERE...
New/Unused AGT 3000PSI Hot Water Pressure Washer (A51573)
New/Unused AGT...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
