MF 135 Orchard..problems with 3 point Hitch not going up
   / MF 135 Orchard..problems with 3 point Hitch not going up #1
robstowing
Harrisville
MF 135 Orchard
I have a Massy Ferguson 135 Orchard Tractor the 3 point hitch won't go up.
I emptied the hydraulic fluid, took the top of the gear box cover off and replaced o rings and
seals, didn't see anything broke, piston pump is moving. Couldn't see anything wrong, cleaned the
relief valve it was okay. Still won't go up. Any ideas that would help?
Thanks Rob
   / MF 135 Orchard..problems with 3 point Hitch not going up #2
Try moving the draft arm back.
   / MF 135 Orchard..problems with 3 point Hitch not going up #4
Did you remove the pin in the linkage before you removed the top cover? If not you need to find it the bottom or it could cause major problems if it gets caught in a gear or something. I'm not an expert on why it won't lift but there is lots of info on the net and other websites.
John Deere 7130 (A53314)
John Deere 7130...
UNUSED LANDHONOR MAP-16-24W MINI MOUNT PLATE (A54757)
UNUSED LANDHONOR...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
2010 Ford Transit Connect Cargo Van (A53422)
2010 Ford Transit...
Plasmarc PM150 Plasma Cutter (A51691)
Plasmarc PM150...
Galvanized Livestock Gates - (2x Gates) (A55218)
Galvanized...
