MF 135 No Hi Gear
   / MF 135 No Hi Gear #1
caitnop
Cannot get our 135 into hi gear. Cannot find an obvious problem. Any suggestions without having to split it?
   / MF 135 No Hi Gear #2
Can you get it in all the gears in low? When the tractor is not running can you then move the shift selector to hi? Does it grind when you try while its running or does the shifter simply just stop when you try to shift into hi?
   / MF 135 No Hi Gear
Everything works fine in low. The Hi Low selctor will go in to neutral as normal. Will not budge into high no grinding at all, moving or stopped. Shifter just stops after neutal.
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
John Deere 772-A Grader (A52384)
John Deere 772-A...
Heavy Duty Jumper Cables (A51694)
Heavy Duty Jumper...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A51694)
2009 Mariah SC23...
City of Buckhannon -Onan 50 Set Stand By Generator (A52384)
City of Buckhannon...
Nissan CF60 6,000lb LP Forklift (A51691)
Nissan CF60...
