MF 135 Generator
   / MF 135 Generator #1
fender316
I have a Massey 135, the generator is a delco with the tach cable coming out the back and two wire connections. I had it rebuilt but when i test it on my tractor both the connections act as ground, there is no power coming out of the generator..any ideas?
   / MF 135 Generator #2
Is there a external Voltage Regulator?
Chris
   / MF 135 Generator #3
G'day i think your prob will be in your regulator check all the wiring to the reg i am not sure on the wiring for them but i am sure that someone here will have a diagram to help you out
Jon
   / MF 135 Generator
the voltage regulator is in the instrument panel near the throttle arm...not sure about the wiring there seems to be so many different models, and this may have been modified over the years. i have the flat-top fenders, continental gas engine. is there any easy way to diagnose the charging system or whether the voltage regulator is faulty?
2015 Ford Taurus Sedan (A51694)
2015 Ford Taurus...
2010 LOAD MAX 40 FOOT GOOSENECK (A53843)
2010 LOAD MAX 40...
2017 TOP HAT TRAILER 16 FOOT UTILITY TRAILER (A53843)
2017 TOP HAT...
200722 (A51247)
200722 (A51247)
2021 Bell TC-11A Crawler Carrier Dump (A52384)
2021 Bell TC-11A...
Enclosed 16ft S/A Cargo Trailer (A51694)
Enclosed 16ft S/A...
