MF 135 Gas Neutral Safety Switch
   / MF 135 Gas Neutral Safety Switch #1
Gpops
Troup, Texas
1965 MF135, Kubota B2301HSD
After not being able to work on my tractor for a long time I am back and close to finishing a rebuild. When I bought the 135 the neutral safety switch wires had been cut. It started fine in neutral and I never tried to start it in gear. Does the switch only come into play if you try to start it in gear ? I tried to search for past posts on this without much luck. Thanks ahead of time
   / MF 135 Gas Neutral Safety Switch #2
The neutral safety switch is designed to prevent the tractor from starting in gear. Both shifters must be in neutral position. Although easily bypassed it is important to keep this feature active. -kid
   / MF 135 Gas Neutral Safety Switch #3
Only the high / low has to be in neutral. The gear selector can be in any gear.
Thanks They are cheap enough so will replace and wire it up. I think you previously mentioned the connectors can be found at hobby shops
Thanks to all !!!
Year: 2020 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 190,820 Plate: Body Type: 2 (A51692)
Year: 2020 Make...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A52748)
2016 RAM 5500...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
2014 Jeep Cherokee Sport SUV (A50324)
2014 Jeep Cherokee...
