TexasChris
Im sure there are many posts about this problem on this forum I just cant find them. Ive now put about 15 hrs on the tractor I purchased about a month ago everything seemed to be working perfectly, all I have been doing is shredding. I am now starting to notice the more and more I use the tractor that the harder and harder it is getting to shift the clutch releases the pto perfectly it just seems that while it releases enough that the tractor completely stops that it doesnt release enough to shift the gears without some grinding less grinding if i lower the rpms before shifting. Is this something that can be adjusted or is this the sign that it is time for a clutch as im sure this the original clutch?
Thanks in advance!
Chris
Thanks in advance!
Chris
