MF 1260 with loader
   / MF 1260 with loader #1
bluecarpenter
central missouri
CK30 HST and allis chalmers b with belly sickle at dads farm. Yanmar 2210DB , ford 8N .farmall cub
MF 1260 with loader
My brother-in-law found a 300 hour old 1260 with FEL. also comes with a brush hog and rear blade. What is it worth? Stated price on it is $14,900. Is that good??
Any body have any specs on it? What size backhoe can go on it? Thanks mark
   / MF 1260 with loader #2
Re: MF 1260 with loader
bluecarpenter,
I have some limited info on the MF1260. The MF1260 and the MF1440 share the same engine. The manufacturer (iseki) rates the engine at 38HP @ 2600RPM. MF added more weight to their 1400 series, but you might compare some of the other features to shed more light on the MF1260. The MF backhoe used on the 1260 is the MF1217, with a 90" deep flat bottom trench. I remember looking at the MF1260 before I purchased my MF1235. The MF1260 was on a larger frame and had larger tires than the MF1235. Both models use the same 1500cc engine, but the MF1260 is turbo'd. The MF1235 engine is rated by the manufacturer (iseki) at 29HP at 2500RPM. Hope this helps. As for the price, there are so many things that might figure. The hours, condition, trany, tires, MFWD, loader etc. BER
it has a little over 300 hours on it. shuttle shift 16 speed tranny. FEL I was told that it doesn't look like it was used very much. Over all in very good shape. Mark
12 FLATBED W/ PRESSURE WASHER FRAME (A50854)
12 FLATBED W/...
1968 International Harvester 856D 2WD Tractor (A50657)
1968 International...
3000 Gallon Black Poly Water Tank (A49461)
3000 Gallon Black...
Caterpillar 730 Articulated Dump Truck (A49346)
Caterpillar 730...
2010 LACROSSE LUXURY LITE TOURING EDITION TRAVEL TRAILER (A50854)
2010 LACROSSE...
STIHL TS420 CUTQUICK SAW (A50854)
STIHL TS420...
