Dlj, here are a few suggestions that may solve your problem. Most are easy, but otherones may require the help of a technician. Hopefully it will be the simple fix. /forums/images/graemlins/grin.gif
1st, have you ever checked the antifreeze in the tractor? If there is too much antifreeze and not enough water, you will have overheating problems. pure antifreeze is a very poor heat exchanger. A 50 / 50 mix of water and antifreeze is always best.
2nd, Have you looked into the radiator for mineral or other buildup that could be inhibiting the flow of coolant through the cores? If there is a build up, you may have to have the radiator rodded out or cleaned to solve your problem. /forums/images/graemlins/frown.gif
3rd, Red line products make a product called Water Wetter that prevents the coolant from foaming or bubbling and improves it's heat carrying capability. I have used this in several of my cars and it does work.
4th, check the suction line going from the radiator to the water pump. It should have a spring inside that will not allow it to collapse fully when you squeeze it or when the engine pulls water from the radiator.
5th, and this may be a long shot, but if the injector timing is retarded, the mixture will not burn efficiently in the chamber which will allow some of the combustion process to be released into the muffler. However, this usually results in a very hot muffler and alot of light grey smoke especially when the tractor is cold.
I have a 4225 with the high vis hood. My muffler is under the hood also and I have no overheating problems.
Well I hope one of these suggestions helps your problem and please keep posting to let us know your progress. /forums/images/graemlins/cool.gif
