wrenchturner
- Joined
- Jun 19, 2006
- Messages
- 171
I just got a 1250 with FEL and BH. Both seem to operate very slowly. Is this normal or am I expecting too much? Have operated Kubota 121 excavator and other tractors.
Your welcome. Has the filter been changed recently and what kind of fluid does it have? I would say that something is wrong with your plumbing or an obstruction is in the lines somewhere if the filter and fluid is all right. It will be slower than the excavator, but should still operate at a good speed. I did have a MF 1250 with a 1217 BH.wrenchturner said:JerryG,
Thanks for the help. I am running the RPM's at 2800. The hoe seems to be operating as if the machine were idling slowly and is also weak. The front end loader is also slow. I do have an older Long 445 with FEL and have operated a Kubota 121-3 evcavator. Also tried out a MF 1240 with backhoe and PTO pump. This tractor has power beyond and two remote outlets. Seems like I do have a problem. So, I will check maximum pressure. But the slow movement is under no pressure so, I must have a volume probmem.
The PTO pump output was 6 GPM, the tractors output is 6.7 GPM. BTW. the pump with complete kit number is 5269 903.jeepcj7 said:The old 1217 backhoe could be ordered with an optional PTO pump to help speed it up. The main hyd pump only puts out about 5 - 6 gpm on that tractor which is fine for the loader, but could be a bit slow for the backhoe.
