MF 120 baler original size tires
   / MF 120 baler original size tires #1
Quickster2
SE Michigan
2005 Kioti DK45, Rhino FEL
I have a MF 120 baler. I've ordered a parts manual off of E-bay. Can anyone tell me the recommended tire size? Mine has a 205 on one side and a 215/70/15 on the "heavy" side. Tires leak bad and the 215 seems to sag even with 45 lbs of air.
   / MF 120 baler original size tires #2
Try the AGCO parts book AGCO Parts Books Click on guest user and then enter your baler info. When I tried it - AGCO Parts Books. Shows #20 843328M1 2 Wheel (Std.)(15 x 4.50K)(6 Hole) (120) If you know your baler weight you could probably run any size that fits this rim, including the big floating agg tires. When I was looking at new baler most dealers were willing to put on what I needed depending on how much on highway towing I was going to do (highway verses agg tire)
Hope this helps
Thanks original parts manual should be here Tuesday. I will go with the Ag tires as my Hesston needs new tires as well.
2018 John Deere 1653 (A53472)
2018 John Deere...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
2012 CHEVROLET 3500HD SILVERADO LS DUALLY TRUCK (A51247)
2012 CHEVROLET...
LMC LOT NUMBER 254 (A53084)
LMC LOT NUMBER 254...
2007 WABASH 53FT DRY VAN TRAILER (A52576)
2007 WABASH 53FT...
