MF 12 Pickup sprocket showing cracks
   / MF 12 Pickup sprocket showing cracks #1
drdoolittle
Loranger, LA
Mahindra 6000
Good evening. Was out looking my square baler today and noticed the sprocket that drives the pickup is cracked on 3 of the for spokes. Will probably be looking to braze/weld it in the morning. However, if that doesn't work would replacing that sprocket (a 2040 pitch 23 tooth sprocket) with a 45 or 48 tooth 40 pitch socket/weld hub work? My logic is since 2040 is basically a 40 pitch "doubled" - 1" instead of 1/2" but otherwise the same chain - if I doubled the count of teeth but left the other end of the chain alone I might be able to run it without having to replace 2 sprockets to just go to a normal 40 pitch chain. If this was later in the fall, I'd probably just replace both sprockets and be done - but have hay that may be getting baled within the next couple of days to a week and would like to know if this would be a quick fix for at least a couple of more runs.
Any feedback would be appreciated.
Thanks,
Eric
   / MF 12 Pickup sprocket showing cracks #2
I'd go for the quick fix, Double count chain should will still lay on the single sprocket. I broke a roller chain once and all I had on hand to fix it was double count master link, it worked!
Thanks. That's what I'm doing. I found the right size at the local parts store so have it. I am going to be trying to weld the old sprocket just because I've never really had a reason to try welding cast iron. But the other sprocket is ready to go and hopefully I'll get the hay up tomorrow.
1987 FORD 2110 TRACTOR (A51222)
1987 FORD 2110...
2014 Peterbilt 320 Altec AH150 Boom Truck (A49461)
2014 Peterbilt 320...
2017 Buick Encore (A50324)
2017 Buick Encore...
1981 Case 245 2wd tractor with Rotary cutter (A51039)
1981 Case 245 2wd...
2015 KENWORTH T800 MID-ROOF SLEEPER (A50854)
2015 KENWORTH T800...
2012 GROVE TMS900E TRUCK CRANE (A50854)
2012 GROVE TMS900E...
