Hey guys, obvious first post....
I have a MF 1165 with front end loader..4x4...rops.. etc. Regularly serviced, in good condition, never had any problems with it.... Runs like a champ.
After using it for some light scraping with a scrape blade the other day, i finished up and came back to the house and parked it. Everything was normal.
The next day i went outside to finish. Get in, gears in neutral, press in the clutch, stick the key in....
First click on the ignition switch and all the lights come on as usual. You can hear the glow plugs clickin'. But when i try to crank it, absolutely no response. Nothing. It doesn't even try to turn over. After looking around, there's no loose wires, everything is in place as usual, etc. Opened up the panel behind the steering wheel (behind ignition/instruments) and found a spring broken. It appears to have gone from the clutch pedal to a hanger on the frame. I got a replacement and replaced it.
Still no luck.
I ran a 12g wire from the battery to the starter (with the key turned on, brake set, everything in neutral, etc)
Starter turns, engine didn't crank.
Here i sit.... any ideas?
Still no luck.
