MF 1145 oil in water
   / MF 1145 oil in water #1
willapplejack
Bonney Lake,WA
MF 1145
Hello
I am new to tractors, purchased a used Massey/Ferguson 1145 at an auction. It was low on water. When I got it home and filled it with water there is oil in the radiator. After it warmed up, oil came out a tube on the right side of the enginge.
Any ideas as to what is cause. ?
Is this a common failure of this engine. ?
Iseki E3AD1
   / MF 1145 oil in water #2
It sounds like a "blown " head gasket. Don't run . Water in engine = expensive repair. Check engine oil level, the radiator is probably draining into the engine, so level will be way high. I would get a mechanic to have a look at your level of inexperience.
   / MF 1145 oil in water #3
oil in the radiator.......this must be your clew ~ Oilpressure will press oil in the watersisteem . Where is the oil next to the water ?
New/Unused 10ft Workbench with 15 Drawers (A51573)
New/Unused 10ft...
2022 CATERPILLAR 980 WHEEL LOADER (A51246)
2022 CATERPILLAR...
John Deere Gator Utility Cart (A50324)
John Deere Gator...
2024 JOHN DEERE 8R 280 LOT NUMBER 7 (A53084)
2024 JOHN DEERE 8R...
New/Unused AGT Industrial SDA-140T Track Loader (A51573)
New/Unused AGT...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
