3-Point Hitch MF 1045 Vertical Link Measurements
   / MF 1045 Vertical Link Measurements #1
F100Panel
Renss. County NY
Usually something with a Loader
I bought a MF1045 4x4 Loader Tractor. I'm suspect in it's previous life it had a frame mounted backhoe that would normally require removal of the vertical and lower 3 point linkages. Now just a loader tractor with 3 point hitch, the hitch lower link drawbars don't seem to have enough lift. When my Yorke Brand yorke rake is on the tractor & properly leveled using the top link, the rake barely rises 6 inches off the ground/the stroke of the lift is maxed out. I'm suspect after the backhoe was pulled and vertical lift links and bottom draw links were put on to make it again a functioning Ag tractor with 3 point hitch the original parts were not used. My first thought is the vertical lift links. They are 24 Inches center pin to center pin. Anybody out there have a 1045 or similar that could tell me the proper length of the vertical links and maybe even the center to center holes on the bottom/draw links?
Wolverine Quick Attach Stump Grinder (A50514)
Wolverine Quick...
UNUSED FUTURE SKID STEER HYD BREAKER (A51244)
UNUSED FUTURE SKID...
2022 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
2017 CASE SR160 WHEELED SKID STEER (A51242)
2017 CASE SR160...
2012 Ford F-450 (A50120)
2012 Ford F-450...
