MF 1010 will not start
   / MF 1010 will not start #1
harmlouis
Cambridge
mf 1010
My 1010 Diesel manual transmission all of a sudden will not start with the key. I tested the start switch start position and there is power. No power at the clutch safety switch . Checked safety switch with an ohmeter and it functions as it should. I can start the machine with a screwdriver by shorting out the solenoid to the starter. If only I could find a schematic on line. I have the Agco wiring harness and components drawing , but it is not a schematic. It lists a fusable link but does not say where it is located . Any help appreciated
   / MF 1010 will not start #2
the fusable link on my MF1040 is near the starter. I changed it out and put in a fusable link that you can replace the spade fuses in. Mine has developed a short in the ignition switch and i have to replace the fuse every time i start it. I wish i knew how to track and fix this sort of thing.
PICKUP TIRE CHAINS (A50854)
PICKUP TIRE CHAINS...
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
2005 International 4200 Texoma UC-301 Pier Drilling Truck (A49461)
2005 International...
19010 (A48082)
19010 (A48082)
2014 PJ 24+6 T/A GOOSENECK (A50854)
2014 PJ 24+6 T/A...
