MF 1010 Price check and parts availability...
   / MF 1010 Price check and parts availability... #1
buck boost
Paris, WI
Ford 4500 LB, M7040HD, B2920
Hi everyone! I have a chance to buy a MF 1010 2wd, gear, with a 54" MMM. It is very clean, and it was always stored inside. Not sure on the hours. I know the mid PTO that drives the MMM is broken, and I don't know what is exactly wrong.
I know it is 13 PTO hp, so not really a powerhouse. How is part support on this older machine? I don't need it, but I could buy it to fix, then resell. I have heard that there is very little part support though. And I don't really know how involving of a repair the mid PTO might be. Any thoughts and/or advice on what it is worth broken? And what it is worth repaired?
Does the mid PTO dump when you step on the clutch like the rear PTO?
Should I stay away?
Any advice would be appreciated.
   / MF 1010 Price check and parts availability... #2
IIRC those models no longer have any parts available for them unless you can find a junked one with a good part that you need. Even 5 years after the model year, no parts were available so not a good choice.
I hear ya Gary. Doesn't sound like a good choice at all. Sounds like a major pain to screw around with. Thanks for the info. 5 years after the tractor is built/sold and no part support, equals very bad juju...
I think I'll pass on this one...
   / MF 1010 Price check and parts availability... #5
good choice Buck...
CASE 850M WT CRAWLER DOZER (A51242)
CASE 850M WT...
2014 John Deere 8360R MFWD Tractor (A50657)
2014 John Deere...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2019 Ford F-150...
2022 John Deere S780 Combine (A50657)
2022 John Deere...
2008 RIB 24 Cat Boat (A50324)
2008 RIB 24 Cat...
