MF 1010 hydraulic pump rebuild
   / MF 1010 hydraulic pump rebuild #1
WhateverTN
Good Evening
Just finished rebuilding a hydraulic pump on our MF 1010 manual 4 wd tractor. The gear does not turn freely when you tighten the bolts down that holds the case together. I didn't take it apart so not sure if turned freely to start with. Thoughts on if it should turn free or what the problem is?
Thanks,
Terry
   / MF 1010 hydraulic pump rebuild #2
I'm getting ready to disassemble the hydraulic pump on my MF 1010 and was checking to see other people's experience. My service manual says to "Secure the drive gear in a vise at the shaft end, and check for smooth turning of the pump. If a seal is stuck, the pump may not turn smoothly. If this happens, disassemble, check and re-assemble properly." Bottom line is the gear should turn freely. Proper torque for the bolts is 25.2 to 28.8 ft-lb.
If you were able to resolve your issue (or not), I'd like to hear from you.
NEW 23hp Land Hero Stand Up Skid Steer (A53002)
NEW 23hp Land Hero...
2008 D&P WELDING 18FT 2000 GAL FUEL TRAILER (A52472)
2008 D&P WELDING...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2009 Freightliner B2 School Bus (A51692)
2009 Freightliner...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
