Solo
Platinum Member
Does anyone know where to get a tool for metric grease zerks. I have a tool to remove SAE zerks and restore threads. I haven't even seen one for the metric ones.
Solo
Solo
Solo said:Does anyone know where to get a tool for metric grease zerks. I have a tool to remove SAE zerks and restore threads. I haven't even seen one for the metric ones.
3RRL said:You can get metric taps at an industrial tool supply store just as easily as super hardened metric bolts. Bolts are not really meant for that anyway. (LOL ... Although like yourself Soundguy, I have done it in a pinch.) I think the metrics are usually 6mm, 8mm or 10mm so those taps are common. Those tap sizes are pretty handy to keep around seeing as a lot of little gadgets on almost all tractor brands now end up having some kind of small metric threads.
Also the chips from re-tapping or chasing tend to be soft (mild) steel. Although certainly not good for the wear surfaces, they are waaaay softer than sand particles that into the joints and bearings. I always try to get out as much of the chips as I can, but I don't sweat it too much. With hydraulic cylinders, it is a must to be free of chips. The rods are usually hard chrome plated but the sleeves are soft in many cylinders. Then there are the "O" rings and glands to worry about. But as far as pivots like on the bucket or other connections like that, they can stand some abuse and still function.
DieselPower said:The part that is metric is the threaded part that screws into the object being greased. The nipple part of SAE and Metric grease fitting's work in any grease gun coupler fitting. If your having problems getting grease into something I would supect that either the fitting's are bad (not likely), they are pluged up (very possible) or just inside past the grease fitting it is cloged with rust (also very likely).
To change from Metric to SAE fitting's you would have to remove the old grease fitting and tap the hole for SAE and then install a SAE fitting.
I would suggest removing one of your problem fitting's, sticking in in your grease gun coupler and see if any grease comes out. If it does then the problem is internal to what you are greasing, ie. cloged with rust or very hard dried out grease.
If you have access to a phenumatic grease gun try that. It creates alot more preasure than a normal hand operated one and will often purge out the blockage.
