boltz
- Joined
- Oct 3, 2010
- Messages
- 33
- Location
- Ontario Canada
- Tractor
- kioti ck30, allis d-17, Cub Cadet Enforcer Zero Turn Mower
Left my blower in unheated garage for 3 or 4 days since last use. When I moved it out today was about a large coffee cup of hypoid on cement floor. Both pto shaft seal and side shaft looked like they had leaked. So pulled fill plug on side of gear box and it was over filled, and liquid was milky, and more white than normal EP. I have never added fluid, since I purchased blower new a few years ago. If it was a car would definitely say water got into box. No indication of leaks out in parking lot and driveway. I always check seals that are visible before using blower, and paint is like brand new on blower, so any leaks should have been obvious. To me there is no way that I could have run it over the past few years if it had been leaking like it just did. So, can it suck water back in past seals when unit it cooling down after use. Have had coldest wx here this winter that we have had for the last 10 or so years. Inside garage is usually about 10-15 degrees warmer than ambient but not this winter, so ice around gear box has not melted as has happened in the past. Sucked all the EP out and replaced with fresh, but only had outboard EP 90 so used it. ( May get a blast for that) Ran blower for about 20 minutes outside and no leaks, and have left it inside tonight, and will check again in morn. Phoned dealer, but tech had left for day. He said bigger model than mine had a vent on top just like a car diff, but mine has none, so how is gear box supposed to vent when it heats up? Level now is to the bottom of fill hole. Owners manual that came with it does not show any vent on box, but is not most detailed. Says to use EP90, which I did. Any one run into this before. Thx
