Metal working safety
/ Metal working safety #41
Very few if any of these chemicals will be in contact with a welder who works on Carbon steel material only. CS has a very small amount of manganese in it to start with so a welder would need to inhale a heck of a lot of fumes in order to even be slightly approaching a THL of chemicals. I would be more afraid of any chemical contact with the material, like degreasers, that may produce fumes that are not so good for you. Basically if it smells bad or is irritating to the nose, I would take action to eliminate it. Lead and zinc contamination is the most frequent culprit to damaging a person in the metal trades.
Proper PPE (personal protective equipment) is essential when handling or welding on any product. Most times this is just leather gloves and a welding hood with proper shade of lens, or it could mean fresh air mask (not from a compressor with oiled bearings), fully enclosed suit to prevent any contact (similar to a biohazard suit) but this is very rare in the metal trades and requires special training to use.
As you stated, ventilation is the key to any contamination issues. Proper smoke removal, even if it is just an open door with air mover of any type with cross ventilation is basically all that is needed for normal welding operations on carbon steel.
Hi Gary,
You are correct, but exceptions do happen, and most importantly, no one knows what they may have inherited or acquired that could make them more at risk for one of the more serious complications or worse case scenarios despite only having some mild, even perhaps unnoticed exposure.
That is why I posted the (sorry about the size of the post) massive list of occupational syndro,es associated with metal-working and welding.
Knowledge is power.
Thomas
/ Metal working safety #42
I watched a u tube video, on how shipping containers were built, all the employs were wearing resporators in the factory.
Dave
/ Metal working safety #43
If you have an oiled compressor, aren't you supposed to avoid breathing the air?
NEVER breath air from a oil type compressor. A condition called lipoid pneumonia can develop. If the oil becomes vaporized - your lungs cannot process / filter the oil. Death is quite possible.
Airline equipped respirators (Type C) is supplied air that is continuously monitored / filtered. The type C filter board has all sorts of bells, whistles and alarms that immediately sound in the air you are breathing becomes contaminated or unfit (lack of oxygen, presence of carbon monoxide, etc). Some systems have a backup escape filter if the air system goes down. The type C system is designed to provide Grade D breathing air.
An ambient air pump is what you would need (what I would use). This is a certified pump that is placed in a fresh air environment. You can have 100' of hose between you and the pump (and 200' ft. from the pump to the fresh air intake.
Short duration tasks could be supplied by SCBA (think SCUBA - only without being underwater.). Firefighters, rescue workers - typically used where the toxins are unknown.
Tons of info out there on the subject. PLEASE PLEASE don't cobble something together and breath your shop air!!!
Thanks for all the feedback! I figure you just cant be too safe when doing this work everyday and I want to plan ahead for the long haul. There are some steps I've taken to improve safety including mounting two 5,000 cfm exhaust fans into the gable of my shop which is about 22' x 75'. I am rearranging it to make an 18' x 21' welding room, walled off from the rest of the shop. This welding room will contain the two exhaust fans and my welding table will be positioned so that I stand upwind from the fumes. That way I can keep the rest of the shop heated during the winter where I spend 85% of my time on the saws, tube bender, notcher, shear, press brake and drill presses. I dont mind if the welding room is cold. Plus in hot summers I will be able to open up a door from the welding room to the rest of the shop to allow the exhaust fans to draw cool air through the entire shop. When the welding room is closed off I will only run one fan for a complete air exhange every 1.5 minutes. On days I want the entire shop ventilated quickly I can opt to run both fans.
I also picked up a Speedglas 9002x with adflo welding helmet. It has flex view to use for grinding too. I'm going to love breathing in clean filtered air while welding! The other benifit with PAPR helmets is that they completely surround your head therefore sparks and reflected UV arc flash wont be getting into the hood.
/ Metal working safety #45
Outback,
After a few weeks, please let us know how the helmet is working out. The ones I found in a search were pricey and I'd sure like to know whether they provide enough comfort to use long term.
/ Metal working safety #46
Hi Outback,
Congratulations on taking some real and positive steps o make sure that your chosen way to make a living doesn't shorten the time you have to live. Too many folks live in a constant state of denial of the risks they take for granted day in and day out, while poisoning or injuring themselves and robbing themselves of their future.
It's a difficult and mature thing to be able to do.
As the Aussies say, "Good on ya, mate".
Thomas
/ Metal working safety #47
What are you doing for intake air?
/ Metal working safety #48
/ Metal working safety #49
A fresh air helmet is the best way to protect yourself from breathing unhealthy air. When I went through my apprenticeship in the 80's at the Northern Alberta Institute of Technology (NAIT), the largest training center in Canada, they said they conducted an extensive study on the hazards of welding. The results were so bad that they never made them public! Two years later they did another study and promised to release the results. The results were never released. I think the OHSA is who requested the studies. Keep in mind that a study like this would cover everything possible and if the general public saw the results, nobody would ever become a welder. There have been a lot more safety regulations put in place though. Proper ventilation in shops for one thing. A lot of it is still up to the individual welder/ worker. Miller has a very compact respirator that fits under a helmet if you don't want to spend thousands on a fresh air helmet. A fresh air helmet is better. Anything that produces fumes or dust has a Hazmat charge when you purchase it. This includes welding rods and wire, gasses, grinding wheels, etc. It's never a bad idea to use protective equipment even if it might not be absolutely necessary.
/ Metal working safety #50
This is the setup I use.
http://bit.ly/RkjkmH
I am a enthusiastic hobbiest at best.
Have been welding about 20yrs but only wearing the respirator the last 2 yrs. better late than never!
This respirator fits well under my miller Digital elite.
/ Metal working safety #51
I work as a safety advisor. On our projects we are required by OHS here in Canada to not only wear the respirators but to also have a regular schedule for changing the cartridges. This has been directed by our provincial regulatory body. Just before the Holiday break we were paid a visit by OHS, they found a welder that was not clean shave under the respirator. He was sent home for 3 days without pay.
As to your concern about heat and comfort, put it this way. Which is least comfortable, a respirator now, or an oxygen tank later in life? I am not a welder but have had to wear them in live processing plants in everything from -20*F to 120*F. The heat excuse to me is not valid. If a respirator fits properly the breath exhaled will go through the exhalation valve, not around the mask itself.
I have also seen a self ventilating welding helmet used. They were Adflo helmets that filtered air and then passed it across the welder's face to eliminate the welding fumes. Many welder's liked them because they had a cooling effect in a hot shop.
There is also full face respirators that combined a welding shield with a respirator allowing you to protect yourself completely from both the fumes and and flying particles from grinding.
Many options are available, just look at 3M and North Safety Products.
/ Metal working safety #52
I guess i been lucky then.;)
Cutted ,welded, mechaniced ,machined, grinded for 40+ years and counting,.. in a shop and outside, sometimes inside the shop the welding smoke was so thick one could not see the walls.
Never even wore safety glasses nor respirators or helmet or gloves.
The only health thing i have is tinnitus and i got that from a gunshot blast close to my ear 30 years ago.
I always work alone.
2014 BRENNER TANK CRUDE TRAILER (A60736)
2014 BRENNER TANK...
2025 Unused SDLGC80 60v Electric Golf Cart (A60352)
2025 Unused...
DOOSAN 7K FORKLIFT GS35-5 (A60736)
DOOSAN 7K FORKLIFT...
WOODS 3120 BATWING MOWER (A60430)
WOODS 3120 BATWING...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2021 ISUZU NPR (INOPERABLE) (A60736)
2021 ISUZU NPR...
