meball said:
I was told to put the scews every 12 inches on the raised hump area. Is this correct? Any help is appreciated.
Mitch
Mitch,
There are a few misconceptions about fastening metal roofs, and most have been mentioned here already.
First, make sure you get good quality screws with rubber gaskets designed for wood. This is extremly important!!! If you use the wrong screws, they will not hold.
When you screw them in, be sure to stop as soon as the rubber gaskets starts to bulge. NEVER over tighten them!!!! If you do, two things will happen. You will destroy the rubber gasket and it's ability to seal out water. Second, you will strip out the wood and stop the threads from holding the roof down.
There are all sorts of metal roof stypes and types, but basically there are two characteristics that seperate them. Corugated metal is has the costant up and down U without any flat surfaces. I kind of think this is what John saw in Latin America. This type of roofing is installed over a wood undermaterial that is cut to form the same pattern of the corugated metal. This is usually nailed on with the nails through the highest point of the metal. It's very common and been around for ever. It almost always leaks over time, but mostly because it was nailed and not screwed down.
Moderm metal roofing like an R panel has flat and raised parts to it (ribs). You ALWYAYS attach it to the purlins through the flat portion that is touching the purlines. You NEVER want to have any void or space between the screw head and the purlin. NEVER!!!!!!!!!
If you fasten through the ribs, you won't find the proper screws because they do not exist. Nobody does this. Next you will have to invent a spacer to fill that void to keep the metal locked to the roof. Just tightening it to the point of holding it down will gurantee failure. It will also void your warentee.
After you fasten the panels down to the purlins, you will have to fasten screw the overlap of the metal panels to each other.
There are two types of screws to use. Metal to metal and metal to wood. Be sure you get the correct ones. Both are self tapping and are needed to get through the metal. The metal to metal screws are needed for the overlap. You will only need a few of them compared to the metal to wood ones.
Be sure you know how to overlap the metal. There are two options. One is right, the other isn't. The same is true for how many screws to put into each purlin. I like to have two screws on either side of the panel and leave the middle one blank. I've seen where just one is used for each panel, but don't feel comfortable doing that myself. I've also seen where three are used, but that's usually when the purlins are over four feet apart and you need the extra strength. With your purlins at 12 inches, I'm thinking two on one purlin, then one on the next with it going back and forth. Of course, two on each purlin will work too, it's just overkill.
For the metal to metal screws on the overlap of your ribs, be sure to put them in every four feet.
Make sure you have a vent, or vents at the peak. I think the number one reason for metal roofs to sweat and create condensation is the heat rises to the peaks, but has no where to go. It forms moisture there and that water runs back down the roof. At the purlins, it drops to the floor. I've seen this in allot of metal buildings and it's always the same thing. No air movement and no peak vents.
16 feet is way too long for an unsuported 2x6 to hold up it's own weight. It will never last with a load on it of any kind. Is the 2x6 part of a truss? How is it supported?
What pitch is the roof?
I've found that clean, white soled sneakers are the best for traction. Dark soles are harder and more slipery. 4:12 is about as steep as I feel comfortable walking on without safetey gear. Any steeper, and you are working on a slide.
Be sure to start early in the morning and work on a dry roof. Morning dew will kill you, so wait for it to go away, then start. It wont take long for the metal to get too hot to stand on. It feels like the bottom of my feet are on fire after awhile and I have to get off the roof.
Get a big magnet with wheels for picking up all the screws you drop. Just run around the building with the magnet to pick them up. Kids love to do this if you have any around.
Don't try to do it all at once. Get enough screws down to hold it in place. You can always come back later to finish it off.
When doing an entire roof, sooner or later you will put a screw through the metal and not find a purlin. It happens. You can usualy put the larger metal to metal screw in the hole to seal it up, or you can fill it with a high quality caulking. I always try to use the screw to plug the hole first, but sometimes you have to caulk. Silicone might work too, but you can't spray paint over silicone. Find a matching paint for scratches and patches.
Eddie
