metal cutting question
   / metal cutting question #1
redhorse0
Frankfort, Ky.
3016 mahindra
I was wondering if I changed the blade in my chop saw to a metal cutting blade, would I be able to cut angle iron and flat stock? thanks
   / metal cutting question #2
no speed to fast blade will burn up.
   / metal cutting question #3
Along with speed being too fast, the motor isn't shielded against the metal "dust" and can lead to a motor burn out. I wouldn't recommend it.
   / metal cutting question #4
You can use a abrasive wheel if your saw is high speed, only downside is it is very dusty, but it will work fine. Also throws sparks real far so take fire precautions. Wear a dust mask as well, that taste is horrible and will ruin dinner for ya!
   / metal cutting question #5
I had an old Makita chop saw that I did this too...but I didn't care if I killed it....it has so far worked well for me
   / metal cutting question #6
Know I will get flamed, but OH Well, not the first time. :D
If you go slow you can cut mild steel with your carbide tipped blade. Does shorten the life a little. But have done it for years. One contractor I know cuts conduit that way all the time.
In certain cases the rock blades also work, sometimes better than the metal diamond blades.
Go slow, be careful, & have fun. :thumbsup::thumbsup:
   / metal cutting question #7
Just buy a cheap angle grinder from Harbor Freight along with a 10 pack of metal cutting disks and have at it. The larger, thicker wheels on chop saws have a tougher time going through thick metal.
   / metal cutting question #8
On this topic I tried a very thin blade on my 12" chopsaw and while it cut fast much faster and did not bog down as the thicker blades often do, I found that it simply would not cut a nice 'square' cut. Seemed to wander.
   / metal cutting question #9
Thats why I prefer the thicker blades with a chopsaw, and you still have to go slow or they will drift. Also I let It run a little after I cut thru, just to let the blade walk itself back and square off the cut.
   / metal cutting question #10
yep.. pressing too hard makes the non square cut. just let it work it's way thru and keep the rpm up and it will be a decent cut..
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52748)
2014 Doyle Dry...
2023 Dynapac cc900 Double Smooth Drum Roller (A51573)
2023 Dynapac cc900...
2016 FORD INTERCEPTOR (A51406)
2016 FORD...
2011 FORD F-650 ROUSTABOUT TRUCK (A52472)
2011 FORD F-650...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
