metal barrel see press / cultipacker
   / metal barrel see press / cultipacker #1
RancherSam
Hays County, TX
Case IH JX95 4x4
I'm planning to build a metal barrel press / cultipacker to run behind my grain drill. This is just an idea and I need input and suggestion. I'm actually going to weld two barrels together to run behind a 10 ft grain drill. Then I will weld a steel plate on either end of the barrel. Then put a bearing on both plates, and run two metal pipes ( 1/18 in) bent in an A frame shape to a pint to connect to a hook on the back of the grain drill. First of all this would be my first time playing aground with bearings. Can someone give me a link or an item number for a bearing and a frame I would attach with to the steel plate. Secondly how do I keep the ends of the pipe in the bearing, since there is no axle running through the width of the barrels. I will be adding water in the barrels as needed to weigh them down. Also, any know of any good barrel places in or around San Antonio, Austin area. Thanks for all the advice in advance.
Sam
   / metal barrel see press / cultipacker #2
might be easier to weld a bar stub to the end of the barrels at the plate and put the bearing on a trailing arm that fits onto the stubs. This would allow you to seal up the barrel assembly.
rick
DRIVE UP RAMPS (A53843)
DRIVE UP RAMPS...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
2021 JOHN DEERE 524P LOADER (A52705)
2021 JOHN DEERE...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2016 VOLVO VNL SLEEPER (A54313)
2016 VOLVO VNL...
2012 OVERLAN KILL TRAILER (A53843)
2012 OVERLAN KILL...
