Mercron 2200 alternator size?
   / Mercron 2200 alternator size? #1
03powerstroke
Koiti Mechron 2200
Was wondering how many amps an alternator on a mercron 2200 puts out? I am putting a electric sprayer pump that is rated at 19 amps max. Will this alternator will be big enough.
Thanks, Randy
   / Mercron 2200 alternator size? #2
Randy, I think your battery size is the bigger question. The alternator on the Mercon will eventually charge your battery, so long as you run it long enough. However, it's your battery that provides the juice to the sprayer. If you're worried about it killing the battery, you could always hook the Mercon up to a trickle charger when you're not using it. If you're going to be spraying full time, you may want to get another battery and hook it up in parallel to have more battery capacity. Otherwise, occasional spraying around the house/farm isn't going to kill your battery....unless you leave it discharged all the time.
Thanks, I was concerned that the charging system could keep up. I like the idea of hooking up another battery in parallel. Will try that.
Thanks for the info, Randy
POWER CORD W/ REEL, 12G WIRE, VICE (A51244)
POWER CORD W/...
UNUSED MOWERKING SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED MOWERKING...
UNUSED FUTURE MINI SKID STEER HYD 4IN1 BUCKET (A51244)
UNUSED FUTURE MINI...
(4) Split Suitcase Weights (A50515)
(4) Split Suitcase...
2021 TAKEUCHI TL8R2 SKID STEER (A51242)
2021 TAKEUCHI...
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A50323)
2004 Sterling...
