Mercedes Diesel?
   / Mercedes Diesel? #1
Christopher
Bisbee North Dakota
Kubota L2550DT
Is there anyone here familiar with the Mercedes Diesel car? most specifically the 300 turbo diesel. I have been told these cars last forever, true? I want a diesel car but I don't want a Volkswagon diesel. Is there anything to watch out for with the Mercedes, since I will be buying used? What about high milege vehicles (250,000+ miles) would you stay away from these? Thanks for any answers, Chris
   / Mercedes Diesel? #2
The 300SD (Turbo 4 door sedan...the 300TD is the "estate wagon") is my favorite Benz.
These engines go alonnnnnnnnng way, but the turbos don't. Since an MB dealer will charge around $1500-$2000 for a turbo replacement, cars with bad turbos can be a great deal. You can buy a rebuilt turbo for a feww hundred dollars or, get the rebuild kit (place in California called Turbo City sells 'em (or did, my info is a few years old) for a couple hundred dollars.
The "Climate Control" systems can be an expensive repair too, so make sure that works.
It probably wouldn't hurt to take the car to a shop before you buy one...a contingency...even better, take it to the shop the seller had it maintained at. They can do a compression test or a cylinder leak down to see if the engine is in good shape.
Old M-B's might be relatively inexpensive, but parts aren't. You shouldn't need much work if you get a good car. For the right price, I've have no problem buying a Benz diesel with 250,000 plus miles.
   / Mercedes Diesel?
Thanks Roy,
I have found one locally for $2,500 (300 turbo diesel 4 door) but it has 300,000 miles on it, I have yet to test drive it, I might try this week, Is this price reasonable?thanks
   / Mercedes Diesel? #4
Hi Chris,
The 300D Mercedes is probably the best diesel passenger car ever built. But that does not mean they are trouble free. The engines are great, they will run 300k+ miles if they've been maintained and have not been overheated. (If these engines are overheated, they will run ok for 50k or so miles, then will lose their ring seal on the cylinders most affected by the overheating. The best years were 1985-1987. 1987 is the last year for the 300D, there were no diesels imported in 1988, and the 350 series began in 1989. The 350 series are not nearly as dependable as the 300 series.
To get a machine to last 300k miles you have to build it with tight tolerances. If it's got tight tolerances then it HAS to be regularly maintained. The maintenance records are the first thing you want to ask for when looking at a particular car. The original owners papers have a maintenance booklet which has a place for the servicing shop to stamp when the scheduled services are done. You want this log to be as complete as possible. And keep in mind, the engine is only a small part of what can go wrong with a vehicle. The transmission, front suspension, a/c and climate control systems, door lock & vacuum systems, power steering components all will require work at some time in the car's life. If the previous owner has not already repaired or overhauled these systems, you will be doing it.
There are many other things to watch out for, and I'll be happy to answer any questions by email, but this should get you started. I recommend you find a good mechanic and have a pre-purchase inspection done of any car you're interested in buying. It's easy to get one of these cars that needs more work then the car's worth, especially since they are all getting to the age they are.
BTW, the gas Mercedes will also run 300k miles, and in many cases can be a better deal then the diesels. They are actually cheaper to maintain, and they are cheaper to purchase since they don't bring the premium in the market the diesels bring. The 300E from 1987 to 1991 in my opinion is one of the best cars Mercedes built, gas or diesel.
HTH,
Dave Perry aka karmakanic
   / Mercedes Diesel? #5
I had a 1990 gas 300E that I bought from my dad at 155K miles. It went to 188K before it needed a new transmission.
Parts are EXPENSIVE $$$$$$$$$! I paid $200+ for the squirell cage blower for the climate control. Labor at a MB dealership can run near $100 an hour (depending on where you live).
I loved that car. I sold it because I couldn't justify paying $3,000 to have a rebuilt transmission put into a $5,000 - $7,000 car. Also, I had overheated it once (plastic on radiator broke) & would have been gambling how long it was before an engine overhaul. If I could have afforded it at the time & had space, for a second car, I would have kept it as an around town car.
If you are a good shade tree mechanic (I'm not) the cost of ownership goes down dramatically. The couple of things I did do myself, I will say that the car was a pleasure to work on. I did not find one rusted on bolt even at 10 years old! Check you local junk yards for donor car possibilites, again this will lower your cost of ownership.
   / Mercedes Diesel? #6
Christopher,
Here is a brain dump on some things about diesel cars that
might be interesting to you.
There is a website that is pretty good for the Volkswagon
TDI, <A target="_blank" HREF=http://www.tdiclub.com/>http://www.tdiclub.com/</A>. I know you said
you did not want a TDI but there are some interesting
discussions about diesel cars on the site besides Volkswagons.
I have seen some talks about the Mercedes diesel on the site.
I would think there has to be a Mercedes specific website
as well.
The TDI is the only new diesel car that I can find for sale in
the US. Apparently the pollution regulations killed diesels
in passenger cars. The TDI is still sold because it was
grandfathered. The manufactuers are waiting until 2006?
when the new clean diesel will becaome available. Once
the cleaner fuel is out there the diesel can be built to meet
the pollution regulations. I was in a Mercedes diesel 8 or so
years ago and the guy had over 250,000 miles on the car.
The interior was a bit ragged but he was having no problems
with the mechanicals. He had bought used.
Hope this helps in some way,
Dan McCarty
   / Mercedes Diesel? #7
Chris;
I agree completely with Dave Perry, he hit every item I have worked on old Mercedes. I'm a weekend mechanic and have spent many hours nursing a '78 280SE and a '87 420SEL. The climate controls, blower motors and vacuum systems will try your patience. Front suspension (tie rod ends, steering damper & possibly steering box/pump) will need work on high mileage cars. The heavier cars eat brake pads and rotors continously. The drive trains are very stout if maintained. Parts are expensive but readily available. I finally sold my '87 after 280,000 miles on the original engine and transmission. I have switched to Toyota, another brand that goes forever. Good luck with your Mercedes choice. They are great cars.
Sim
   / Mercedes Diesel? #8
Mercedes area great cars and will last forever if, and only if they are properly maintained. Maintenance is not cheap, nor are parts.
   / Mercedes Diesel? #9
Dave, aka karmakanic,
I was looking for and found a 87 300d 6cyl non turbo euro spec with 50K in 96 now has 117K replaced the complete exhaust and radiator, brakes etc to date. I get 38 MPG and it's a great car to own. Had a Merkur Scorpio before so can deal with the parts issues that go with these cars. They say they are $$ to maintain I find no more than the average car since I fix what's broken plus do what I call pre-emptive maintenance - don't just replace the part, fix what caused the problem.
I have friends with the 80-85 series 300TD's 5 Cyl turbos and they still say these are some of the best series built. I like my 300 and would buy another in a minute.
Regarding pricing an 85 300TD (non wagen) for $3500 for a good condition car is in range with less than 200K mi, althogh expect good records and condition for this price. You can find a decent 87 in this area for about $4-5000. gas, but very few diesel.
Carl
   / Mercedes Diesel? #10
I'm rapidly forgetting most every thing I knew about MB 300TD (non-wagen) 4 door sedan with nearly 300,000 miles. It was a great car. 5 cylinder turbocharged diesel. Same engine as the larger, heavier, roomier, and more luxurious SD. Just enough pep to be safe to drive in SOCAL on freeway, do not recommend the SD as it performs slugishly(same engine much more weight). No matter what don't get a 240D (D stands for dog! it really is.) Wife loved her MB but we sold it to friends in prep for move to south central Oklahoma. She thought it would be a social stigma in our rural venue. They are not rare on the interstate or in Oklahma City, but don't see many around here.
There was a series of years with catalytic thingies in front of the turbo. The cat things fail and break up and go through the turbo. MB replaces them under waranty but it isn't worth being stranded at random intervals. Our MB was an '82 and did require some initial maint (due to prev owner defering some) but then was essentially trouble free year after year after year. the A/C compressor costs $800.
Patrick
2019 Ford Fusion Sedan (A51694)
2019 Ford Fusion...
2012 Big Tex T/A 20 ft. Gooseneck Trailer (A53117)
2012 Big Tex T/A...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A53473)
2003 International...
14' Bi-Parting Gate (A50120)
14' Bi-Parting...
2023 MAXEY G8X 26FT TILT BED GOOSENECK TRAILER (A54607)
2023 MAXEY G8X...
2019 TRITON TRAILER ALLMAND MAXI LITE 45 GENERATOR (A53843)
2019 TRITON...
