Melroe M600 lift cylinder seal kit
   / Melroe M600 lift cylinder seal kit #1
Jerry H
Kennebunkport, Maine
Melroe Bobcat M600
I own a Melroe Bobcat M600 skid steer. Starts and runs great but my lift cylinders are leaking a bit. Anyone have part numbers for seal kits? I own the service manual but not the parts manual. After I repair the leaks I'll figure out why I only have one speed forward (only goes about as fast as a slow walk)! I'd love to know the year of manufacture but I have no way to cross reference the serial number....
   / Melroe M600 lift cylinder seal kit #2
Welcome to TractorByNet!
I moved your thread to the Bobcat Construction forum. :)
   / Melroe M600 lift cylinder seal kit #3
There is an online parts catalog available at <www.Bobcat.com>. Go to Parts & Service tab, Genuine Bobcat Parts, then look to right side of page there is a column to choose "Parts Catalog - internet explorer required". That will get you into the main catalog.
600 is a variable belt drive machine, not hydrostatic drive. The levers are only full engaged forward, reverse, or neutral. There should be a lever either on left side of seat, or pedal on the floor that will control the variable belt (ground speed of machine).
8" CHANNEL IRON UP TO 25' LONG (A51247)
8" CHANNEL IRON UP...
2014 Ford F-150 Pickup Truck (A51692)
2014 Ford F-150...
2023 MAXEY G8X 26FT TILT BED GOOSENECK TRAILER (A53426)
2023 MAXEY G8X...
2023 CATERPILLAR 299D3 SKID STEER (A51246)
2023 CATERPILLAR...
