Mechanical vs Hydraulic PTO on CK3510
   / Mechanical vs Hydraulic PTO on CK3510 #1
farmerarty
Ontario, Canada
Currently Shopping
Tractor newbie here. I looked through the forums but couldn't find an exact answer to my question.
The Kioti standard CK3510 HST offers a mechanical PTO whereas the SE model has a hydraulic PTO. Can someone tell me what the difference is? I know the hydraulic version uses more HP, but I don't know what the difference is, what is preferred, etc?
Thanks!
   / Mechanical vs Hydraulic PTO on CK3510 #2
The PTO isn't hydraulic but rather the clutch that engages it is electric-over-hydraulic. So, instead of pulling a lever then releasing a clutch to engage the PTO, you turn an electric switch, which triggers a solenoid to apply hydraulic pressure to a clutch, which then engages the PTO. I think they do this to enable the "auto PTO" feature which disengages the PTO when the 3pt is lifted.
   / Mechanical vs Hydraulic PTO on CK3510 #3
I'll add that the only thing that causes the same version of tractor to have a lower pto hp is if it's a Hydrostatic drive vs manual gear shift. For example my CK20s claimed 17.1hp at pto (gear) vs 16.2hp at the pto for the Hydrostatic drive. This is because the pto is driven off the transmission. There's pro's and cons to both transmission offerings. And as the tractors get bigger you get more manual transmission offerings potentially. Frankly even though I've got a manual likely for more users a hydrostatic drive is the best choice.
I would suggest consider the type of work you want to do, the implements needed, the power they will require and then size the tractor accordingly and get something that will have a bit of power to spare at the pto vs being maxed out to do the job. Same thing for manual vs hydrostatic, consider your tasks. Personally I'd suggest like I said above hydrostatic will likely be the best choice, certainly for a smaller tractor, in my mind I think I'd only really want manual if I was doing heavy field work and I'm sure there's users out there that will even argue that. Anyway, if you're doing odd jobs, loader work, really anything that involves back and forth vs just being at one speed for a extended periods hydrostatic is your friend.
The only reason I got a geared tractor was that it was cheap and I grew up with geared tractors so it's what I know. I can work the gears and not hurt my clutch doing loader work but I know ultimately hydrostatic would have been a better choice for what I do.
Bit long-winded but I hope that helps you a bit.
E.
2011 INTERNATIONAL MA025 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2011 INTERNATIONAL...
2005 Mitsubishi Lancer ES Sedan (A51694)
2005 Mitsubishi...
2012 John Deere 7280R MFWD Tractor (A52748)
2012 John Deere...
2000 INTERNATIONAL 4700 (A52472)
2000 INTERNATIONAL...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
TRUCK FLATBED (A52472)
