mechanical thumb for backhoe
   / mechanical thumb for backhoe #1
toolaholic
What's the pros and cons vs. hydraulic one? I'm also a welder, thinking of fabbing my own. would use it to set rock ect. thank's, Tool
   / mechanical thumb for backhoe #2
I have a mechanical on mine and the only thing I could think of would be not having to climb off and on the tractor to set it up.
   / mechanical thumb for backhoe #3
The only con side I have heard of is $$$$, aside from that I think everyone would get a mechanical thumb instead of a fixed thumb.
If you can fab your own, a few pieces of steel sitting around the shop, would be easy to find. Then go buy a hydraulic ram, hose and fittings, it seems like you solved the $$$$ problem that the rest of us run into.
steve
Thank's guys. I use to weld full time shop has plasma ,mig, and stick.
tons of iron. Tool
2006 International 9400i (A53473)
2006 International...
(INOP) CATERPILLAR 314 EXCAVATOR (A51247)
(INOP) CATERPILLAR...
2015 JCB 525-60T4 5,500lb 4x4 Rough Terrain Telehandler (A51691)
2015 JCB 525-60T4...
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
2013 Freightliner M2 106 Water Truck (A53117)
2013 Freightliner...
