Mechanical Tach Repair
/ Mechanical Tach Repair #1
TimberHole
Platinum Member
Missouri
JD9504WD w/ 75 Loader, JD345, Bobcat S150
My JD 950 has the original tach. It is in excellent cosmetic condition and has a perfect face. It is indicating about 600 rpm's low.
Does anyone have any experience repairing mechanical tachs? We used to have a great speedo shop here in the Midwest but they are gone to the best of my knowledge. According to my research the guts of the tach is a spinning magnet with a calibrated spring. We'll call it electromechanical magic :) The only good news here is that since there isn't any electricity involved I probably won't let any smoke out :)
I'm thinking I will split the unit and see what's going on inside. If anyone has experience with this let me know. Otherwise I'll pull it and see if I can figure anything out.
Thanks.
/ Mechanical Tach Repair #2
I have some experience repairing speedos and tachs.
Well, I have experience in trying; I never succeeded once.
But if I have another broken one, I'll try again!!
Thanks Cincy. I just called him and he doesn't work on the old stuff anymore.Good try though.
/ Mechanical Tach Repair #7
Remove the drive cable and check the ends. Then remove the cable from the casing and grease it with thin/light grease.
Most of the times problems with a mechanical tach is a dry drive cable.
/ Mechanical Tach Repair #8
Boomer has a point there; you can also replace the inner part, get a kit from any auto parts store.
Caterpillar TH255C Forklift (A63689)
Caterpillar TH255C...
2005 VOLVO EC290B EXCAVATOR (A59914)
2005 VOLVO EC290B...
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
2017 Ford F-150 4x4 Pickup Truck (A64556)
2017 Ford F-150...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2018 Freightliner M2 106 20Ft. Reefer Box Truck (A64194)
2018 Freightliner...
