Measuring Drawbar pull
   / Measuring Drawbar pull #1
Shell Farm
JD 4010
Simple to modify hydraulic cylinder with psi gauge to measure lbs of pull exerted by tractor when pulling.
Can determine DB horsepower if speed is determined mph and convert to ft/min.
1 HP is 33000 ft.lbs/minute
   / Measuring Drawbar pull #2
   / Measuring Drawbar pull #3
If you go to the Nebraska Tests, et al, they usually can provide this info. This data is based on tests conducted on a concrete pad.
Using the piston/air pressure method you can do this for the soil conditions you are operating in.
   / Measuring Drawbar pull #4
Or just enter your tractor model into the Tractor Data website. They use NT in their tests.
Land Honor Quick Attach Hitch Adapter (A50514)
Land Honor Quick...
2003 Maverick Boat with Trailer (A50324)
2003 Maverick Boat...
UNUSED FUTURE BOX OF MISC RATCHET STRAPS (A51243)
UNUSED FUTURE BOX...
2008 Dodge Ram 1500 (A50515)
2008 Dodge Ram...
1996 CATERPILLAR 416B BACKHOE (A51242)
1996 CATERPILLAR...
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
